Forums >> Revit Building >> Technical Support >> Revit 2011 products hang when creating or opening a project
Fri, Apr 23, 2010 at 6:30:04 AM | Revit 2011 products hang when creating or opening a project
4 Stars: 205 Votes
Issue
After launching Revit® 2011 when you attempt to create a new project or open an existing project Revit will hang.
Solution
The cause of the hang may be a conflict with the ArchVision® Content Manager Location.  By default the ArchVision Content Manager is set to network with an address and port of 127.0.0.1 \ 14931.
If set to local, and an executable location is not defined, Revit 2011 products may hang when opening or creating projects until the RPC Content Client dialog below is dismissed:
To reset the content location to the default network settings:
If you can open Revit:
  1. R > Options > Rendering.
  2. Set the ArchVision Contnt Manager Location > Network.
  3. Set Address > 127.0.0.1
  4. Set Port > 14931
If you cannot open Revit:
  1. Open the Revit.ini file.  The Revit.ini file is located in the following folder locations:• Autodesk Revit Architecture 2011C:\Program Files\Autodesk\Revit Architecture 2011\Program• Autodesk Revit Structure 2011C:\Program Files\Autodesk\Revit Structure 2011\Program• Autodesk Revit MEP 2011C:\Program Files\Autodesk\Revit MEP 2011\Program
  2. Locate the following lines in the Revit.ini:[ACMSettings]ACMOnNetwork=ACMNetworkPort=
  3. Modify the lines to match below:[ACMSettings]ACMOnNetwork=1ACMNetworkPort=14931
  4. Save the Revit.ini file.
  5. Launch Revit.
See the original post here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15040187&linkID=9243099&CMP=OTC-RSSSUP01
Edited on: Fri, Apr 23, 2010 at 6:31:23 AM
Fri, May 7, 2010 at 9:14:02 AM | Revit 2011 products hang when creating or opening a project
gebber
gebber Avatar
5 Stars: 4 Votes
Thanks Ty,
 I read the pol but still made the mistake.
Fri, May 7, 2010 at 10:03:12 AM | Revit 2011 products hang when creating or opening a project
4 Stars: 205 Votes
Gebber did you check also this thread? http://www.revitcity.com/forums.php?action=viewthread&thread_id=20346
Thu, Oct 14, 2010 at 5:04:29 PM | Revit 2011 products hang when creating or opening a project
tonymack
3 Stars: 2 Votes
Hello folks,
I had the same problem. I tried to solve this error with the latest update to Revit
2011 x64 (i´m runing W7 x64 Ultimate), and following the steps suggested, but it still happening... Do you have tried other way to solve this problem ?
All attempts to modify the material result in error and closing Revit. Can it be related to a corrupted library materials?
Thanks, Tony.
Revit 2011 Hang on Material Painter
Thu, May 27, 2010 at 7:50:17 AM
How to have Revit files open in 2011 instead of 2012
Tue, Jul 19, 2011 at 10:02:45 AM
AutoDesk Products
Fri, Jan 3, 2020 at 1:08:56 PM
Seeking Advice:Creating Arched Opening with Tapered Columns
Thu, Jan 13, 2011 at 7:15:32 PM
Download Revit 2011 for Free...Now!
Tue, May 11, 2010 at 8:08:50 PM
Page generation time: 3.4867
