Forums >> Revit Building >> Technical Support >> Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 12:27:03 AM | Column to diagonal beam/brace connection problem
rdelgadillo
Hi Everyone,I'm having trouble joining diagonal beams to a column. I am using Revit Architecture 2010 and I just can't find a way to join them (see attached image). I don't need it for sections or details, it's more for renderings/3d model.Thanks in advance
Fri, Apr 23, 2010 at 4:37:23 AM | Column to diagonal beam/brace connection problem
4 Stars: 205 Votes
Did you "play" with the "Coping" tool?
Edited on: Fri, Apr 23, 2010 at 4:38:04 AM
Fri, Apr 23, 2010 at 4:40:24 AM | Column to diagonal beam/brace connection problem
4 Stars: 205 Votes
Or with the "CUT" tool??
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
column-beam connection
Tue, Jan 12, 2010 at 5:46:46 AM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
Brace that goes through a girt. Best way to break the brace?
Fri, May 10, 2013 at 11:29:35 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Page generation time: 1.5700
