Forums >> Revit Systems >> Technical Support >> tv in revit
Thu, Apr 22, 2010 at 5:39:02 PM | tv in revit
emorocks
good afternoon all
i have i question, i am trying to render a tv with an image. when i do it on artificial interior it just shows like a white light and with the sun hitting it looks great, i have tried different settings on luminece on the decal options with no good results
can somebody help me? i just want to make look like a tv rather than a fram with a picture  or how do you recommend me to work this around?
thanks in advance
Fri, Apr 23, 2010 at 3:39:40 AM | tv in revit
gebber
gebber Avatar
5 Stars: 4 Votes
Hey emo,
I hanen't tried to make a TV using a decal.
I did try to use a material as the screen, in your materials you can select and size the image then you can set the Self-Illuminnation to for example LED Screen and choose the same image for the filter color.
You can use the texture alignmment to align the image to the screen.
This might not be the easy way but it does work.
Fri, Apr 23, 2010 at 4:26:16 AM | tv in revit
4 Stars: 205 Votes
It work with a Decal too, you must "play" with the properties of the decal....Brigtness, transparency and so one, look my image attached...
Edited on: Fri, Apr 23, 2010 at 4:28:54 AM
Fri, Apr 23, 2010 at 6:40:28 AM | tv in revit
gebber
gebber Avatar
5 Stars: 4 Votes
Looks great Ty,
I must say the whole image looks great whit all those light fx's.
I'll try the decal next time.
Sat, Apr 24, 2010 at 2:07:30 AM | tv in revit
emorocks
hey thanks
i have tried like crazy and i have the same result. cant do it, could you show me an example with interior artificial only and one with sun only? what properties you choose?
thanks again
Sat, Apr 24, 2010 at 12:34:55 PM | tv in revit
4 Stars: 205 Votes
Here you have....
Sat, Apr 24, 2010 at 3:16:36 PM | tv in revit
emorocks
great thank you
my mistake was i used the option of lcd screen on luminance
i appreciate your help
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:02 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:24 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:52 PM
16
Page generation time: 1.4732
