Forums >> Revit Building >> Technical Support >> Wall with horizontal and vertical battens
Thu, Apr 22, 2010 at 3:55:48 PM | Wall with horizontal and vertical battens
unconvention
Hi Guys
I need to create a wall which has a layer that consists of vertical battens and another layer that consists of horizontal battens both with air gaps in between them. I imagine this would be possible with a curtain wall but does that not then make it difficult to put doors and windows in? All my walls will be simple straight walls.
I am using Revit Architechture 2010.
Would appreciate any advice you can give
Rob
Thu, Apr 22, 2010 at 4:01:20 PM | Wall with horizontal and vertical battens
You could do this with wall sweeps.  The vertical would have to be in-place rather than in the wall definition.  I would do them both in place.
I might think about doing the battons as an in-place family and use a void to cut where I need it it the in-place family.  Category would be wall.  All the horizontals would be one extrusion and all the verticals would be another.  Then the void extrusion.  Pretty simple.
Edited on: Thu, Apr 22, 2010 at 4:02:40 PM
Angled battens
Fri, Jun 13, 2008 at 4:22:34 PM
Wall with exterior vertical battens
Mon, Jun 12, 2006 at 10:23:53 PM
Wall with battens
Sun, May 5, 2013 at 8:43:24 AM
Adding Battens to Wall
Mon, Nov 19, 2007 at 3:33:19 PM
Can you add vertical + horizontal elements in a wall sweep at certain intervals?
Mon, May 25, 2009 at 8:30:21 AM
Page generation time: 2.7177
