Forums >> Revit Systems >> Technical Support >> painting a door
Thu, Apr 22, 2010 at 12:33:02 PM | painting a door
iamian33
iamian33 Avatar
Probably a dumb question ... but how do I change the colour of a door?  I am adding an overhead sectional (garage) door to a home addition but the colour needs to change.  I can't seem to find the best way to render the door to a more desireable colour.  Ideas ??
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Apr 22, 2010 at 12:46:29 PM | painting a door
Edit the family and set the extrusions to something other than default...something you can change in the project like OH Garage Door
Thu, Apr 29, 2010 at 1:14:10 PM | painting a door
iamian33
iamian33 Avatar
Thank you for this suggestion.  It was helpful but I was hoping that Revit had a simpler way to get there ... perhaps in 2011 ??
Ian Shafer
Fri, Apr 30, 2010 at 4:10:45 AM | painting a door
4 Stars: 205 Votes
What do you mean with: "but I was hoping that Revit had a simpler way to get there ..." do it like WW told you, edit the family, select the panel (whatever) of the door, go to the properties and in the material parameter youhave in the right side a little button where you can ADD PARAMETER, then assign the name for material... after thiswhen you load into project that doo, if you wabt to cange the color of the panel, just click on the door and go to properties, select the material oprtion and change the colour (material) you want....Simple
painting schedule
Tue, Jun 25, 2013 at 7:27:08 AM
massss painting
Wed, Mar 21, 2012 at 10:36:21 AM
Painting Doors
Thu, Sep 4, 2008 at 9:23:43 AM
Again with take-off....
Mon, Jul 7, 2008 at 6:53:08 AM
Painting Single Walls
Wed, Oct 17, 2007 at 9:10:34 AM
Page generation time: 0.1476
