Forums >> Revit Building >> Technical Support >> Array on an angle
Thu, Apr 22, 2010 at 11:06:48 AM | Array on an angle
jsel13
'm trying to make a parametric trellis, where the arrayed blades are on the angle and sit within a frame.
i've made a bunch of louvers in the horizontal and vertical planes, but i cant seem to figure out what is going wrong with the one i'm making on an angle.
when i go to rotate the frame, i get an error message and it unlocks the array from the frame to which its attached, its super frustrating. the blade itself is a family and i unchecked the keep vertical button already. i used the array "Last" and i took off the Constrain.  i'm not sure what else to do
I'll attach images of what i have and if someone can help id greatly appreciate it. thanks
-the screen shot shows the panel family that wont work and the blade family
-the trellis image shows the panel i originally made but it didnt work on an angle either, so i remade to work on the angle
Thu, Apr 22, 2010 at 11:11:01 AM | Array on an angle
I don't understand.  If it is a family, it should rotate just fine... and it looks like it has in your image.
Thu, Apr 22, 2010 at 11:12:56 AM | Array on an angle
jsel13
when i go to rotate it to a different angle, it unlocks.  can i attach the file so you see what i mean?
Thu, Apr 22, 2010 at 11:14:35 AM | Array on an angle
4 Stars: 205 Votes
You must sure you align and constrain those blades in the 3 axis, check this tutorial, maybe it help you...
http://www.revitcity.com/tutorials/arrays_and_nested/
Thu, Apr 22, 2010 at 11:18:44 AM | Array on an angle
jsel13
i actually just read it, and i locked it in all three planes, and then i go to rotate it again and i get an error message that says, Constraints are not satisfied, and when i go to remove the constraints, it unlocks the constraint i had for the last blade against the frame.
Thu, Apr 22, 2010 at 11:48:56 AM | Array on an angle
jsel13
i attached the file, do you think maybe you can take a look and see what i'm doing wrong? id really appreciate it, im kind of stuck and i'm running out of ideas, i've already remade this thing 3 times
Fri, Apr 23, 2010 at 9:19:08 AM | Array on an angle
4 Stars: 205 Votes
OK, I nested your "blade" family into a new "Line Based" family, then, i nested the Line Based into your final family, after this you know... just apply the parameters and constrain them to your family, it's more easy sometimes to control this... take a look...
Edited on: Fri, Apr 23, 2010 at 9:19:46 AM
Fri, Apr 23, 2010 at 9:36:10 AM | Array on an angle
jsel13
wow.. you're awesome. thank you so much!
Fri, Apr 23, 2010 at 9:48:31 AM | Array on an angle
4 Stars: 205 Votes
Your Welcome... sometimes "Arrays" is a pain in the heck... you know that....
Fri, Apr 23, 2010 at 9:50:23 AM | Array on an angle
jsel13
Fri, Apr 23, 2010 at 9:53:39 AM | Array on an angle
#11
jsel13
Yeah they are. thanks again!! works like a charm. my only question is that originally i was able to stretch the louver panel's length and width because if i remember correctly it was a Instance Parameter. was there a reason you switched it to Type, or am i dreaming and was it originally a Type parameter?
Fri, Apr 23, 2010 at 11:06:34 AM | Array on an angle
#12
4 Stars: 205 Votes
No, i change the parameter to TYPE but you can change if you want....
Fri, Apr 23, 2010 at 12:44:38 PM | Array on an angle
#13
4 Stars: 205 Votes
Here you have the FINAL family.... use this
Is Solution to Creating a Parametric Polar Array?
Tue, Oct 22, 2013 at 8:40:06 PM
Constrain array of elements and make it rotate with another element
Fri, Jan 15, 2010 at 7:36:13 PM
Two row of brick corbel on the Gable roof, just follow roof angle.
Tue, Jan 26, 2016 at 1:21:37 AM
how can I array along spline? [ 1 2 ]
Fri, Nov 28, 2008 at 7:07:32 AM
19
Array along a curved path
Tue, Nov 11, 2014 at 9:11:45 AM
Page generation time: 1.3596
