Forums >> Revit Building >> Technical Support >> cut or slice
Thu, Apr 22, 2010 at 12:44:16 AM | cut or slice
bjwson
2.5 Stars: 3 Votes
Hi All,
i've got this questions, (1) i have used solid form / solid sweep and created a wall (sloping from one side) and i have a roof that is sloping over this wall (created also by solid form / solid sweep) and the wall is sticking out of the roof. now i want to know how to subtract (in cad terms) or slice or cut the wall that is extra. i know there is a way of removing by using void form / void extrusion, is that the only way. (2) i want to attach (like a normal wall & roof) these to entities (roof and wall) created by solid form / solid extrusion, is there a way. pls. help i'm working on this project right now.
thanks
JW
Thu, Apr 22, 2010 at 5:32:18 AM | cut or slice
4 Stars: 205 Votes
You create your wall and roof using the "Create in-place" right?
to answer the 1º - Yes, use the "Void" in the same category you create the wall and cut that portion you don't want..
2º because you create those element in a "in-place" family you CAN'T attach the wall to the roof like you can in regular walls/roofs, the only way is EDIT that in-place wall and create the shape to "Attach" to the roof...
Thu, Apr 22, 2010 at 9:53:40 AM | cut or slice
bjwson
2.5 Stars: 3 Votes
thank you for the clarification, is there a chance to do this in revit 2010, i mean can you imagin how many void sweeps one would endup by the time a project is done....(every time there is a slope in roof and a funny shaped wall is projecting) cheers....do post or update with any work around that may or might pop up in near future...
JW
Thu, Apr 22, 2010 at 10:16:10 AM | cut or slice
4 Stars: 205 Votes
by the way... why don't you put here some images (3D) to clarify your issue and we can have another perspective about that?
Mon, Apr 26, 2010 at 1:12:49 AM | cut or slice
bjwson
2.5 Stars: 3 Votes
As you can see the sloping wall's in the front (both sides of glazing) as well as the rest of the walls, ofcourse i've used void sweep n got rid of the projections. pls. find attached.
JW
Cutting a Massing Cube with a slice in the corner
Sat, May 7, 2011 at 5:07:10 AM
slice massing object?
Wed, Apr 6, 2005 at 2:56:21 AM
Ending facia trim edge.
Thu, Oct 10, 2013 at 8:28:22 AM
editing split face boundaries
Wed, Jun 4, 2008 at 9:26:52 AM
How to Undo parts
Mon, Feb 1, 2016 at 5:45:02 PM
Page generation time: 2.6838
