Forums >> Revit Building >> Technical Support >> Door Families and Profiles
Wed, Apr 21, 2010 at 4:22:32 PM | Door Families and Profiles
reide
Hello, I am using Revit Architecture 2010; my goal is to figure out how to get my door families to show profiles when cut in plan and section. This has worked for me with Curtain Wall Mullions but I don't find anywhere that I can load a profile into a door family. Any Ideas?  Thanks.
Wed, Apr 21, 2010 at 4:29:50 PM | Door Families and Profiles
You have to load a detail - not a profile.
BTW - I really have found this to be a bad process and unneeded.  Add frame details to detail views is a better process.
Thu, Apr 22, 2010 at 1:06:47 PM | Door Families and Profiles
coreed
coreed Avatar
4 Stars: 16 Votes
you should be able to find some doors familys with frames that show in plan when cut in the download section. use this as a staring point to create your own if you must.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Save Profiles
Fri, Dec 17, 2010 at 1:13:23 PM
Nested "Profile" Families
Tue, May 4, 2010 at 1:01:52 PM
Create Legend of (Stone) Profiles
Fri, Oct 14, 2016 at 8:37:12 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Profiles, sweeps, and door frames...
Tue, Mar 3, 2009 at 7:03:51 AM
Page generation time: 0.9585
