Forums >> Revit Building >> Technical Support >> importing topo info into RAC 2010 to create a toposurface
Wed, Apr 21, 2010 at 11:15:47 AM | importing topo info into RAC 2010 to create a toposurface
iamian33
iamian33 Avatar
Howdie.
I am hoping to find a way to import topographical information into RAC 2010 to create a toposurface.
I am able to create the toposurface based on CAD info from the surveyor/civil engineer (importing), and I have also created toposurfaces manually by identifying points.  But I have clients (home owners) wanting their designs but they do not have topo information.
I've been able to 'fudge' a toposurface based upon simple observation of their site, but I am hoping to find a process or a web-site that will help me and provide some reasonably accurate topographical information.
Does anyone have any suggestions ??
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Wed, Apr 21, 2010 at 12:04:11 PM | importing topo info into RAC 2010 to create a toposurface
Find a USGS map on line of that area and create it from the information on it.  That will get you to +/- 1 foot I think.  That's the best U can do unless you shoot it.  I have done that using a level (not a surveyor device - carpenter's) but even that is not very accurate.  Close enough for houses if you understand surveyor process.
Wed, Apr 21, 2010 at 12:28:21 PM | importing topo info into RAC 2010 to create a toposurface
coreed
coreed Avatar
4 Stars: 16 Votes
if they are actually going to build on this site, then they should have a survey done. if they are not, then what you fudged should be suffficent. why find ways to detour the procees. i'm sure they would like their design without paying for it too.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 23, 2010 at 6:29:56 AM | importing topo info into RAC 2010 to create a toposurface
Kardiff
5 Stars: 3 Votes
Give it 5/10 years and Google will release a Google survey
 Like google maps but with topo points of all of the uk on a 500mm x 500mm grid
Until then just fudge it like you have or do a simple survey of the site with a disto a level and a stick ?
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Thu, Apr 29, 2010 at 1:12:40 PM | importing topo info into RAC 2010 to create a toposurface
iamian33
iamian33 Avatar
Thank you all.
I like to offer as much to my clients as possible, althought it is nice to get paid too :o).  When I have their survey info, it is usually jsut a hard copy so I must input all the data manually.  when I work with the Civil Engineer or surveyor I can usually get the info from them ... this is a great help, of course.
Perhaps google will come thru but until then, I will jsut have to make do I guess.
Ian Shafer
Importing AutoCAD Topo - Import Symbol Issue
Thu, May 3, 2007 at 12:49:35 PM
Fri, Feb 2, 2007 at 12:28:14 PM
Civil 3d surface to revit topo surface
Thu, Oct 13, 2011 at 7:14:34 AM
IMPORTING TOPOSURFACE PLEASE HELP
Wed, Jan 14, 2009 at 3:41:02 PM
Image Overlay onto Toposurface 2010
Wed, Sep 23, 2009 at 12:32:32 PM
Page generation time: 0.9221
