Forums >> Revit Structure >> Technical Support >> Leaders
Wed, Apr 21, 2010 at 11:12:17 AM | Leaders
ad330coupe
In Revit 2010 where is the leader button, also some tags have an arrow head, others dont, how can i change this?
Thanks
Wed, Apr 21, 2010 at 11:40:05 AM | Leaders
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
Find the tag you want to change in Families under annotations, right click on the tag you want to change and select properties, you have the option to add whatever type of arrowhead you want from the drop down.
stanmpd
Belz A&C
Memphis, TN
Wed, Apr 21, 2010 at 11:54:53 AM | Leaders
ad330coupe
Great thanks, does it apply to text notes too?
Wed, Apr 21, 2010 at 11:59:44 AM | Leaders
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
For text notes, when you go to Annotate tab on your ribbon and select text, the contextual ribbon for annotations populated with the commands that are specific to text.  you will have 4 options for your leaders; No Leader, One Segment, Two Segments and Curved.  The actual style of the leader is set up under your text style.
stanmpd
Belz A&C
Memphis, TN
Leaders moving_Annoying
Fri, Jan 20, 2012 at 7:37:30 AM
Multiple Keynote Leaders
Wed, Sep 24, 2008 at 1:27:58 PM
Multiply Leaders with Keynotes!
Thu, Nov 1, 2007 at 8:25:02 AM
Goofy arcs with dimansion leaders
Fri, Feb 22, 2008 at 1:44:32 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Page generation time: 5.7331
