Forums >> Revit Structure >> Technical Support >> roof slopes with skylight openings and notch
Wed, Apr 21, 2010 at 9:21:31 AM | roof slopes with skylight openings and notch
westminster30
Hi revitalistas!
 I've been checking the forum for a possible answer.  I have a pent-up roof and it looks fine when the roof is rectangular.  The roof, however, has skylight openings and a notch.  I go to edit boudaries (or footprint) and weird roof slopes appear.
 This is what I did --
--I drew my rectangular roof (1-1/2" metal deck)
--after giving it an elevation height, I drew in my split line and added elevation points to both ends.
--I go to edit boundary, I draw in the openings.  Weird roof slope appears.  I add in elevation points the skylight openings and to the inside of the notch.
Am I doing this right?  I don't think I should be seeing those lines.  plus, in the section view, it doesn't look right.
 Also , and I'm just wondering -- I'm working with just the structure aspect of the revit model.  What difference does it make if I draw a floor as the roof or draw the roof under Architect & Site.  I've always drawn it as a floor (mainly because that's what I've been instructed to do).
 If anyone could help, that would be great.
 Thanks,
Westminster30
75583_ScreenHunter01_Apr._21_09.53.gif75583_ScreenHunter02_Apr._21_09.54.gif75583_ScreenHunter03_Apr._21_10.03.gif75583_ScreenHunter04_Apr._21_10.03.gif
Wed, Apr 21, 2010 at 9:31:12 AM | roof slopes with skylight openings and notch
westminster30
I know what's wrong with it, but I'm not sure on how to fix it.
The openings and notch isn't going along the slope.
Wed, Apr 21, 2010 at 9:37:30 AM | roof slopes with skylight openings and notch
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Why don't use the "opening by face" tool? go to modeling>opening by face... you have to use the roof tool for it... In my opinion, if you're modeling a roof - use a roof tool not a floor tool.
 "If you tell the truth, you don't have to remember anything"
Wed, Apr 21, 2010 at 9:45:31 AM | roof slopes with skylight openings and notch
westminster30
I will try that.
 Thanks!
westminster
Wed, Apr 21, 2010 at 9:46:21 AM | roof slopes with skylight openings and notch
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
correction.... you can use the opening by face tool in any planar surface.
Wed, Apr 21, 2010 at 10:26:18 AM | roof slopes with skylight openings and notch
westminster30
thanks!
It works great for the skylight openings.  But what about the notch?  If I edit the footprint, it's as if I'm editing on a flat surface.
W
Wed, Apr 21, 2010 at 10:42:09 AM | roof slopes with skylight openings and notch
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
just create an in-place generic void form extrusion... you can set the of your extrusion there... then use cut geometry to show the notch.
Wed, Apr 21, 2010 at 10:44:53 AM | roof slopes with skylight openings and notch
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
you can set* your extusion there...
Wed, Apr 21, 2010 at 10:46:48 AM | roof slopes with skylight openings and notch
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
argh!!! i meant to say... you can set your extrusion DEPTH there.
Wed, Apr 21, 2010 at 11:00:05 AM | roof slopes with skylight openings and notch
westminster30
lol!  I will try that.  thanks, grinheart!
Wed, Apr 21, 2010 at 12:49:19 PM | roof slopes with skylight openings and notch
4 Stars: 205 Votes
One Question: Did you try with the "Vertical Opening" tool in that Slab/roof???
Wed, Apr 21, 2010 at 1:09:29 PM | roof slopes with skylight openings and notch
westminster30
No, I did not try that -- but good to know!  Thanks!
 I would think there's an easier way to modifying the roof edge...
 Thanks, guys!
Skylight with slopes in 2 directions
Fri, Jun 7, 2019 at 10:54:49 AM
Tubular Skylight / Light Projection / Building Construction
Thu, Nov 6, 2014 at 8:28:07 AM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Skylight Family - Host Roof showing up in main model
Fri, Aug 5, 2011 at 8:46:46 AM
Skylight shaft
Tue, Sep 2, 2014 at 4:03:45 PM
Page generation time: 0.4921
