Forums >> Revit Structure >> Technical Support >> Formula Syntax for PI
Wed, Apr 21, 2010 at 7:49:14 AM | Formula Syntax for PI
WmMerrill
Is there a syntax formula for PI ... 3.141593 .... and so on ... ?
Wed, Apr 21, 2010 at 7:56:34 AM | Formula Syntax for PI
> - What do you mean syntax - PI is PI ... it is a number - as you have written it.
Wed, Apr 21, 2010 at 8:10:23 AM | Formula Syntax for PI
WmMerrill
If in a formula, I would like to use something that the system knows is pi.  Autodesk has included syntax for square roots, absolute values, logarithms, exponential powers ... but what about the all important PI.  I have looked and cannot find ... I have tried both pi and PI and Pi in the formulas.
Wed, Apr 21, 2010 at 8:46:49 AM | Formula Syntax for PI
Available functions and the syntax for their use is given.  The value assigned to PI is not but this is no big issue.  Just use a number with the number of places that you want.
Wed, Apr 21, 2010 at 9:45:11 AM | Formula Syntax for PI
coreed
coreed Avatar
4 Stars: 16 Votes
create your own variable/shared parameter "PI" and set it equal to 22/7
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Apr 21, 2010 at 9:52:51 AM | Formula Syntax for PI
WmMerrill
This is what I ended up doing.  I personally would prefer to keep my shared parameters to a minimum but if it has to be done ... so be it.
 Thank you.
Thu, Sep 13, 2012 at 6:20:34 PM | Formula Syntax for PI
bruff730
pi()
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:51 AM
RAC2009 Formula for Mirroring an Object?
Mon, Sep 29, 2008 at 9:04:19 PM
Parameter names with dashes - problem with formula
Tue, Aug 31, 2010 at 10:28:39 AM
Syntax issue: Left Parenthesis is Not Expected
Thu, Sep 3, 2015 at 5:34:21 PM
What is the syntax error in this pattern
Sun, Sep 27, 2009 at 11:25:25 AM
Page generation time: 0.1400
