Forums >> General Discussion >> Revit Project Management >> how to make walls opaque in a camera view
Wed, Apr 21, 2010 at 7:36:53 AM | how to make walls opaque in a camera view
Dthon
I am a revit mep 2010 user, i need to take some camera angle views for the purposes of a brochure. when i make a view and go to it all the mep equipment shows through the walls as if they were transparent. how do i change the settings or manipulate the view so the items on the other side or behind a wall dont show through?
I checked the linetype and it was already set to hidden lines...how do i make the walls opaque?
Wed, Apr 21, 2010 at 7:59:59 AM | how to make walls opaque in a camera view
Is your view (not lines) set to hidden line?
Are the materials the wall is made of transparent?
Are the walls in this view over-ridden in VG making them transparent?
Are the MEP items in a linked file?
Wed, Apr 21, 2010 at 8:05:56 AM | how to make walls opaque in a camera view
Dthon
yes me view is set to hidden
the walls are standard 4" stud walls with drywall
the mep file is not linked byt the architectural is linked to our mep file
checking the vg graphics for theview now
Wed, Apr 21, 2010 at 8:19:29 AM | how to make walls opaque in a camera view
Dthon
so walls aren't even an option in VG for the MEP file...should i check the architectural file i have linked to it?
Wed, Apr 21, 2010 at 8:55:38 AM | how to make walls opaque in a camera view
I don't use MEP but I think this is similar.  In VG, there is a checkbox to "show categories from all disciplines" - check that and walls should be available.
Wed, Apr 21, 2010 at 11:20:43 AM | how to make walls opaque in a camera view
Dthon
ok it worked  i was able to find the walls in VG however, they are not set to transparent but still show that way
 attached is a pdf of what i'm looking at...my goal is to not have components on the other side of a wall be visible
Wed, Apr 21, 2010 at 2:09:14 PM | how to make walls opaque in a camera view
According to some others that posted in the chat your problem may be the VP graphics/discipline setting.  I don't use MEP so I don't know the affect changing that setting will do for you.
Fri, Jan 4, 2013 at 10:24:28 AM | how to make walls opaque in a camera view
MTerry
Has anyone figured out a solution to this problem?
Fri, Jan 4, 2013 at 10:47:32 AM | how to make walls opaque in a camera view
Check what happens if you change the discipline of the view.
Fri, Jan 4, 2013 at 11:22:18 AM | how to make walls opaque in a camera view
MTerry
Nevermind, I figured it out. I had to change my view template discipline from electrical to coordination.
Structural columns and most walls are black in camera view.
Thu, Mar 27, 2008 at 1:02:04 PM
Materials in a camera view
Mon, Mar 25, 2013 at 8:17:41 AM
Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 19, 2014 at 10:32:39 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 1:12:58 AM
Windows gray and opaque in 3D view
Fri, Aug 19, 2016 at 6:49:44 PM
Page generation time: 1.7114
