9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> model fill patterns
24 Posts No Rating |
Hi all,
I have a problem with model fill patterns showing up upside down. I'm using a fish scale shingle pattern - on some walls it shows correctly, on others it's upside down. I have the same issue with a wood shake pattern. Anyone have any advice? PDF elevation attached...
Thank you!
Karen Maxon LineWright |
Did you try to turn it manually? I just created a wall and put a shake pattern on it and them I was able to turn it 180 so it was upside down.
Well, I'll be! It worked! Thanks so much - Sometimes the simplest thing is the hardest to recognize...
Karen
Model Fill Patterns |
Tue, Jun 22, 2010 at 11:35:19 PM
Fill Patterns Drafting / Model |
Tue, Sep 8, 2009 at 8:06:40 AM
Rotate Model Fill Patterns |
Wed, Sep 2, 2009 at 11:01:18 AM
14
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
