Forums >> Revit Building >> Technical Support >> Trimming roof with roof/floor
Mon, Apr 19, 2010 at 12:25:33 AM | Trimming roof with roof/floor
mooingchicken
Hey,
Just a quick question. I am modeling up a building with a saw tooth roof that meets with a flat roof half way along the building but i need to trim the saw tooth roof along the red line, and remove everything that is on the left. The flat roof section is a floor slab that has been coppied up. Is this possible? OR do i need to re-draw this as a roof to be-able to do this?
 Using Revit MEP 2010
 Thanks.
Mon, Apr 19, 2010 at 6:06:34 AM | Trimming roof with roof/floor
Kardiff
5 Stars: 3 Votes
I would re-draw it but if you just change the profile to match what you want it should be easy
go to your site plan and draw your profile so it buts up to your roof, and then if it delets any of your elevation points redraw them
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Mon, Apr 19, 2010 at 6:06:47 AM | Trimming roof with roof/floor
4 Stars: 205 Votes
Try to use the "Vertical Opening" in the "Modify>Openings"
Mon, Apr 19, 2010 at 5:00:38 PM | Trimming roof with roof/floor
mooingchicken
When i try to use the vertical opening i just get the error "The roof couldn't be cut." as soon as i click the button, before any user input.
Is there a way to you can draw a profile on both sides? as i have drawn the roof profile in elevation (see pic) but i need it to come across on an angle, as it dosnt butt up square with the other roof.
Mon, Apr 19, 2010 at 6:25:43 PM | Trimming roof with roof/floor
mooingchicken
Tue, Apr 20, 2010 at 5:20:27 AM | Trimming roof with roof/floor
4 Stars: 205 Votes
Look at my image above, i go directly to "Modify>Openings>Vertical Openings"... Can you put here only those two Roofs, so we can take a look?
Edited on: Tue, Apr 20, 2010 at 6:30:54 AM
Sun, Nov 4, 2012 at 7:43:04 PM | Trimming roof with roof/floor
safsum
Hi I really need to know how you created that sawtooth roof, ive been trying to work this out for hours...
Mon, Nov 5, 2012 at 3:27:40 AM | Trimming roof with roof/floor
4 Stars: 205 Votes
Roof > Extrusion
Joining a Floor to a Roof????? Help!
Sat, Mar 5, 2011 at 12:42:27 PM
Roof Join at a Corner
Mon, Aug 27, 2007 at 10:33:22 AM
Trimming roof in Revit 2009
Mon, Jul 27, 2009 at 9:30:31 AM
Roof/Floor mass problems
Sun, Oct 25, 2015 at 7:27:41 AM
Revit 8 -First Floor Roof Adjacent Second Floor Walls
Sun, Oct 1, 2006 at 7:57:59 PM
Page generation time: 0.4096
