17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> problem with lighting
2 Posts No Rating |
I have downloaded several lighting fixtures off of the revit city families and I am having trouble with them showing up in my program when I load them. I have only been able to see a few lighting fixtures that I have downloaded but I need help with others.
are the light you downloaded hosted? if so, are they ceiling or wall hosted? and do u actually put them on a wall or ceiling?
also, they might be offset from the ceiling or floor. try to go to 3D view wireframe and from the project browser, right click the light you want to find (under families) and select all instances, see if anything is highlighted.
HTH
Lighting fixture problems |
Wed, May 10, 2017 at 9:52:09 AM
13
Lighting Fixtures show black in rendering but light in different angles |
Tue, Jun 3, 2014 at 7:55:10 AM
Revit 2009 in 3D Studio Max Design lighting issues |
Mon, May 5, 2008 at 6:03:59 AM
problem with connecting flexible pipe to lighting with gland |
Fri, Jul 31, 2015 at 12:55:02 PM
Annotations in lighting |
Sun, Sep 11, 2005 at 6:59:36 PM
