20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Rotate drawings
18 Posts No Rating |
hi all. does anyone konw if Revit can rotate the view for 45 degrees when we drop it on a sheet? i can only choose for 90. its a whole set of units and wondering what if i rotate the whole lots just for print porporse and rotate back afterwards?will that cause any problem as level grid and attachment?thanksEdited on: Fri, Apr 16, 2010 at 5:52:42 PM
Edited on: Fri, Apr 16, 2010 at 5:54:04 PM
yes you can. If the view is on a sheet. Activate the view! Then choose the crop boundary and rotate it to what ever you want. Have fun.
thanks alot! it did work. cant believe its simple as that! thanks again
ROTATE ELEMENT |
Mon, May 16, 2011 at 8:15:08 AM
3d rotate |
Fri, Sep 28, 2018 at 7:16:26 AM
Component rotate |
Tue, Feb 8, 2011 at 10:55:46 AM
How to rotate family componenent? Example Dryer |
Thu, Jul 14, 2005 at 2:28:39 PM
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings) |
Sun, Feb 24, 2013 at 1:00:00 PM
