Forums >> Revit Building >> Technical Support >> Sharing Families and details between users and projects
Fri, Apr 16, 2010 at 12:10:07 PM | Sharing Families and details between users and projects
alexsharum
Hey everyone
I have a question as far as sharing families and details between users and projects. Currently we have only two people using Revit and we are setup on a network. When we use or make new families we usually save them to the imperial library that is located on our harddrives. We do use a template that we start a project with everytime.
We would like to be able to save them to shared file so that in case we need the families later on we can access them easily and quickly. Would it be a good idea to make an "imperial library" on our server and start saving them there so that we can both access the families at any time? Or is there a way to "link" the Stock Revit imperial libraries on our harddrives so we can search each others libraries for families?
Thanks for the information
Edited on: Fri, Apr 16, 2010 at 12:12:07 PM
Fri, Apr 16, 2010 at 12:13:40 PM | Sharing Families and details between users and projects
We keep our office created families in a seperate folder in each category of the main Revit library.  Then when an upgrade comes, we can copy these up and upgrade them to a new version.  I suggest you have a simple naming convention that identifies your content in a different way than stock items.
Fri, Apr 16, 2010 at 12:17:57 PM | Sharing Families and details between users and projects
alexsharum
Thanks WWHub for responding. That sounds like a good strategy. However by doing this can two people access the same Revit Stock Library? As of right now I have most of the families stored on my revit library on my computer and my partner can't access these families without asking me to import them into the projects.
Fri, Apr 16, 2010 at 12:30:27 PM | Sharing Families and details between users and projects
Everything should be on your network ... including your central files.  Only keep local files on your system.   Assign a librarian.
Fri, Apr 16, 2010 at 1:34:00 PM | Sharing Families and details between users and projects
alexsharum
Yep. Thank You. Is there a way to repath the stock imperial library to a server?
Fri, Apr 16, 2010 at 1:48:31 PM | Sharing Families and details between users and projects
Put the files on your server then in everyone's Revit, Open Revit, pull down the R - goto options and reset the path for the templates project template and rendering file. Your library paths can be set in the load family GUI.
Sharing Revit Models and content - BIM 360, etc
Fri, Jan 11, 2019 at 4:17:08 PM
sharing notes with other projects
Sat, Dec 29, 2007 at 3:25:56 PM
utilizing Master Project File w/ linked building models (sharing details) (2017)
Wed, Dec 21, 2016 at 1:52:05 PM
Revit 2008 - Family sharing
Sat, Dec 29, 2007 at 3:42:25 PM
Local and Central File locations
Tue, Sep 12, 2006 at 8:36:57 AM
Page generation time: 3.1936
