Forums >> General Discussion >> Revit Project Management >> Why Can't My Computer Complet A Rendering
Fri, Apr 16, 2010 at 5:52:56 AM | Why Can't My Computer Complet A Rendering
albertstwrt
4 Stars: 8 Votes
I just built a new rig with a water cooling sytem and Quad Core @ 3.6 & 8GBs of ram...... And with all this Horse Power she still can't do a 3.3 mb Rendering in Revit 2010........ I know, check the Task Manager, been there and done that........ Even Max crashes when trying to bring in a Fbx....WOW....... Weird... Can you help me?
Fri, Apr 16, 2010 at 7:34:23 AM | Why Can't My Computer Complet A Rendering
If you are on a 32 bit machine, you can only use 4 gig.  If on 32 bit, have you set the 3 gig switch?
If you are on a 64 bit machine, is your graphics card up to spec?
Fri, Apr 16, 2010 at 9:21:32 AM | Why Can't My Computer Complet A Rendering
albertstwrt
4 Stars: 8 Votes
Yes I'm on a 64 bit machine with Windows 7 Ultimate.
Here in my video card spec.
                                         ATI Radeon HD 4800 Series
  Driver Packaging Version_____________________________ 8.702-100202a-0.95693c-ATI
  Catalyst Version           ______________________________ 10.2
  2D Driver Version           ______________________________ 8.01.01.1004
  2D Driver file Path        ______________________________ Registry/Machine/System
  Direct 3D                    ______________________________ 8.14.10.0738
  Open GL Version         ______________________________ 6.14.10.0551
  Catalyst Control Center Version ______________________ 2010.0202.2335.42270
  Memory Size              _______________________________ 512 MB.
  Memory Type             _______________________________ GDDR5
  Core Clock in MHZ.     _______________________________ 750 Mhz.
  Memory Clock in MHZ._______________________________ 900 Mhz.
  Total Memory Bandwidth in G Byte/s __________________ 115.2 G Byte/s
Fri, Apr 16, 2010 at 9:32:03 AM | Why Can't My Computer Complet A Rendering
4 Stars: 205 Votes
Hi Albert, that is a Good machine, very nice horse you have, just a question: do you have already turned ON the Direct3D in Revit?
Edited on: Fri, Apr 16, 2010 at 9:33:34 AM
Fri, Apr 16, 2010 at 9:56:20 AM | Why Can't My Computer Complet A Rendering
Here are the requirements for 64 bit system.
Microsoft Windows 7 64-bit Enterprise, Ultimate, Professional, or Home Premium editions; Windows Vista 64-bit (SP2 or later) (recommended), including Enterprise, Ultimate, Business, or Home Premium edition; or Windows XP Professional x64 SP2*
Windows 7 or Vista processor: Pentium 4, AMD Athlon dual-core, 3.0 GHz or higher with SSE2 technology, or Quad Core Intel® Xeon® W3570 3.20GHz, 8M L3, 6.4GT/s Turbo or equivalent AMD processor (recommended)
Windows XP processor: Intel Pentium 4 or AMD Athlon dual core, 1.6 GHz or higher with SSE2 technology
3 GB RAM (8 GB or more recommended)
5 GB free disk space
1,280 x 1,024 video display with true color
Display adapter capable of 24-bit color for basic graphics or 256 MB DirectX 9-capable graphics card with Shader Model 3 (recommended)
Microsoft Mouse-compliant pointing device
Internet Explorer 7.0 or later
Download or installation from DVD
Internet connection for license registration
Fri, Apr 16, 2010 at 11:53:10 AM | Why Can't My Computer Complet A Rendering
albertstwrt
4 Stars: 8 Votes
Let me check and see if it is turned on....... I'm on my laptop right now. Thinks Ty, and thinks WWHUB........
But Ty, let me check that out.
Fri, Apr 16, 2010 at 12:34:16 PM | Why Can't My Computer Complet A Rendering
albertstwrt
4 Stars: 8 Votes
Ty, can you tell me how to turn on direct 3d?
Fri, Apr 16, 2010 at 1:06:14 PM | Why Can't My Computer Complet A Rendering
Under the Revit R pulldown - Options - then the graphics tab.
Your dream computer setup for rendering in Revit?
Mon, Nov 26, 2007 at 4:35:27 PM
Question on Revit Rendering in Quad Core Computer
Wed, Jun 10, 2009 at 11:38:38 AM
Rendering Walkthroughs [ 1 2 ]
Thu, Jul 16, 2009 at 3:03:37 PM
18
Distributed Rendering
Mon, Aug 17, 2009 at 2:02:38 PM
Rendering Performance [ 1 2 ]
Wed, Feb 15, 2012 at 6:14:36 AM
16
Page generation time: 5.7908
