Forums >> Revit Building >> Technical Support >> Elements can't be copied because they will lose their References.
Thu, Apr 15, 2010 at 4:49:43 PM | Elements can't be copied because they will lose their References.
RainaMc
RainaMc Avatar
Hello all
Working in Revit 2010.  I am building an in place family with various extrusions and sweeps.  I have redone and rebuilt it in several different ways and just when I have it built exactly like I want it and hit FINISH MODEL it gives me the "Elements can't be copied because they will lose their References." Error message.  I have rebuilt it 3 times making sure to not copy any extrusions or sweeps.  I also notice it is highlighting a wall sweep in the model not with in the in place family when it is giving me this error message.  What am I doing wrong?  I just don't get it.  If anyone has any information for me or knows why Revit does this and how I can avoid this please let me know.
Thank you,
Raina Mc
Fri, Apr 16, 2010 at 6:00:56 AM | Elements can't be copied because they will lose their References.
Thread Post Kudo! #2
4 Stars: 205 Votes
Hi Raina... well if you attach something in the Create in-place family with "Something" in the Wall, or whatever, you have that kind of error but try this (I don't have Revit Here) create a "Group" with that family and try to copy that Group....
Fri, Apr 16, 2010 at 9:11:20 AM | Elements can't be copied because they will lose their References.
RainaMc
RainaMc Avatar
Hello Typhoon.
I have an extrusion with a sweep on top and then another sweep on that.  Then I have joined geometry on the sweeps and extrusions and all of this is on a wall  Is that what you mean by attach?  Grouping and copying won't do because each item is similar but not identical.  I stopped copying and revising the sweeps and extrusions and just doing each one idividually but still the same error was occuring yesterday.
I am currently going back through the in place family and adding one peice and doing it one step at a time to see when the error occurs and today no error so far.  I just don't understand where it is going wrong.  I am going to keep on building it back to the point I was at yesterday and see if it will work.  Is it possible I am trying to put to much stuff in one family.
Thank you,
Raina Mc
Wed, May 13, 2015 at 4:43:24 PM | Elements can't be copied because they will lose their References.
bcnuckelt
I had the same problem and finaly realised the issue was with using the face of a sweep as the reference plane. You can basically  select any other face (or make a new workplane) except a sweep and it'll work fine. Just hit undo until you get back to the sweep profile, and select another surface parallel to the original plane.
Change a copied lever to an original level
Mon, Apr 19, 2010 at 11:26:41 AM
There is a circular chain of references among the highlighted elements.
Tue, Aug 30, 2005 at 4:56:01 AM
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:34 AM
Problem using 'paint tool' within copied groups - Revit 2013
Wed, May 22, 2013 at 2:43:14 PM
Beams that are copied are invisible, while beams placed can be seen??
Sat, Jan 20, 2007 at 9:53:43 AM
Page generation time: 0.8742
