9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Export Issue from revit to navisworks
Hi, I am using Revit 2010 & Navisworks Manage 2010. When we export directly from revit to Navisworks then it cause flashing effects. I have checked all option in Navisworks export setting but no soluton was there. Also it is exporting a solid wall as single faces... Is there any option while exporting to navisworks. DWF works fine but i have added desriptions, values which have no meaning to export via DWF
Now on the implementation stage.... |
Rams, Are you sure there is not "values" in the DWF's. I see them in Navisworks Freedom
We get only few parameter values. I want to see all the parameters..
ARe the values you want shared parameters - only shared export. Could that be your problem?
2016 export Revit files to Navisworks without using Navisworks Exporter. |
Thu, Apr 21, 2016 at 4:53:15 PM
Planting/ Trees not appearing correctly in Navisworks with NWC export |
Sat, Jan 20, 2018 at 3:44:33 AM
Origin Issues when Exporting to Navisworks |
Fri, Jan 13, 2012 at 2:03:14 PM
Navisworks Question |
Tue, Apr 28, 2015 at 1:17:16 PM
Navisworks to Revit |
Thu, Aug 25, 2011 at 11:11:37 AM
