Forums >> Revit Structure >> Technical Support >> steel column comes out dashed (hidden)
Wed, Apr 14, 2010 at 11:31:57 AM | steel column comes out dashed (hidden)
lalaindahouse
For some reason, my steel column, which goes all the way up, is coming out dashed.  While all the other ones are normal.
 i'm stumped.  I looked through my visibility graphics and didn't see anything out of the ordinary.
help is, as always, very much appreciated.
 Lala
hidden steel columns showing as solid
Tue, Nov 23, 2010 at 12:18:43 PM
LINESTYLE OF HIDDEN STEEL COLUMNS
Mon, Jan 17, 2011 at 5:25:38 AM
Lineweight of steel column in coarse view
Fri, Jan 7, 2011 at 6:25:48 PM
HSS column hidden lines not showing up
Sat, May 7, 2011 at 4:34:57 PM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:41 PM
Page generation time: 2.1285
