Forums >> Revit Building >> Technical Support >> Detail Levels
Thu, Sep 22, 2005 at 1:09:37 PM | Detail Levels
arccodex1
3 Stars: 1 Votes
I've linked 7 buildings into a topo model and I'm having trouble getting cetain parts of the buildings to plot. Window mullions won't plot in elevation view and roof patterns won't plot in the site plan view nor will either show up in a plot preview. I tried modifying the detail level but it's doesn't help. Any suggestions? Under PRINT SETUP I changed Vector Processing to Raster Processing and this seems to have solved both problems. Post edited on 2005-09-22 16:37:30
Thu, Sep 22, 2005 at 6:57:30 PM | RE: Detail Levels
eldados
eldados Avatar
4.5 Stars: 8 Votes
I would first check to see that your windows are in the current phaze... might need to do it in each file.
Detail levels
Sun, Nov 20, 2005 at 4:00:07 PM
Multiple detail levels of walls in same view
Fri, Nov 28, 2014 at 9:51:04 PM
Can I set text visibility to hide/show at different view detail levels?
Tue, Sep 15, 2009 at 6:56:43 AM
how to draw objects in the right scale?
Sun, Apr 10, 2005 at 9:38:18 PM
a question about detail levels..i guess
Thu, Oct 14, 2010 at 2:04:03 PM
Page generation time: 3.2338
