Forums >> Revit Building >> Technical Support >> Wall Hosted families
Thu, Sep 22, 2005 at 12:54:37 PM | Wall Hosted families
archdan
3.5 Stars: 2 Votes
I have created a wall hosted light fixture and when I load the family into a project the component either floats off of the wall or is partially buried in the wall. Is there any way to lock the dimension so that the edge is flush with the finish face fo the wall? Ideally I would like fixture to stay the same distance from the wall if I change wall types.
Thu, Sep 22, 2005 at 3:23:00 PM | RE: Wall Hosted families
TomDorner
4.5 Stars: 25 Votes
Place a reference plane in your family, align and lock that reference plane to the face of the wall, then align and lock your fixture to the reference plane. Then FLEX-FLEX-FLEX. Within the family editor change the host wall thickness and see what happens, change again and see what happens (both fat and skinny walls). HTH Tom
Thu, Sep 22, 2005 at 4:45:49 PM | RE: Wall Hosted families
archdan
3.5 Stars: 2 Votes
Thanks it worked great. I got it to work and I think I have done it the way you suggested, but at this point in time I am going to call it good and not mess aroudn with it any longer. Post edited on 2005-09-22 16:46:39
Wall hosted Families question
Thu, Jan 3, 2008 at 7:04:01 PM
Wed, Feb 11, 2009 at 7:29:20 AM
Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 3:40:49 PM
Wall hosted family appears in schedule, but not in a room
Sat, Nov 19, 2011 at 12:58:14 PM
Wall hosted components in groups............ [ 1 2 ]
Fri, Nov 3, 2006 at 8:09:00 AM
15
Page generation time: 0.7062
