12 Users Online (10 Members):
Forums >> Revit Structure >> Technical Support >> moment connection symbol to appear bigger in plans?
20 Posts No Rating |
i'm just wondering if it's possible. i opened the beam to edit family and don't see where i could modify the size. it just would be nice if they came out a little bigger  thanks.
ok, this is very simple on your project browser under families right click on Connection-Moment-Filled and select edit. modifie it and the re-load to project.
wow. Thanks!!!
Also, is there a way for the cantilevered moments to have the filled symbols, instead of the not filled symbols? right now, i have them as regular moment connections, just so the triangles come out solid.
if i understand right, you want to show your canterlever symbols not solid? in any case if you are using 2009 go to setting and click on structural setting if you are using 2010 go to manage and the click on structural setting, there you can change that.
no, i want to show them solid (filled-in) they don't let me choose, so i guess it can't be done... but thanks, anyways!
yes you can
moment connection symbol |
Wed, Oct 19, 2011 at 3:31:19 PM
MISSING MOMENT FILLED CONNECTION |
Wed, Apr 4, 2012 at 9:34:26 AM
Moment Connection symbol rotates on radiused beam |
Thu, Jul 14, 2011 at 4:04:36 PM
Moment Frame symbol is grey |
Fri, Jul 28, 2017 at 7:51:13 AM
Moment connection problem |
Tue, Apr 22, 2008 at 4:56:26 PM
