Forums >> Revit Building >> Technical Support >> Rendering Scratch Disk size
Tue, Apr 13, 2010 at 12:19:27 PM | Rendering Scratch Disk size
Theodor
I'm attempting to create renders for print, but I'm getting the disk space error, as Revit wants at least 35 gigsfor the temp folder.
I'm using revit on a Mac in a windows partition, but the entire windows partition is only 30 gigs, so there is no way I can make the required disk space.
Is there a way to re-route the TMP file location onto an external hard drive or reduce the size on the temp file without dramatically comproising the render quality? I don't really want to rebuild my windows partitionIf I can avoid it.
Thanks in advance.
~T
(Oh, I'm using Revit Archhitecture 2010)
Rendering help (size of image)
Thu, Feb 2, 2012 at 10:04:02 AM
Can a 63mb Revit File Size cause problems during rendering?
Mon, Nov 2, 2015 at 6:29:45 AM
How Large Can A Rendering Be Blown Up?
Fri, Jan 15, 2010 at 2:10:26 PM
creating tables from scratch
Fri, Mar 27, 2009 at 11:41:06 AM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:18 AM
Page generation time: 0.3366
