15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Sales plan - Black in where cavity closers have been
20 Posts No Rating |
Hi Can anyone jhelp with this as i have had a good look but cant find solution. I know it will probs be in the setting but i have a sales plan where all walls are blacked in but i still get the cavity closers, if these are off how do i get these ares to blck in/ have a fill Any help appreciated and i attach a file to show what i am after
Not sure what you mean. If you want chase spaces to be black like your walls, you will have to add fills. There is nothing in a chase to turn black.
WWHub thanks for reply. I just read my original post and it was a bit messy. Yes i want the white boxes left filled black as i have turned off the closers. I presume you mean that i have to go round each one and add a black solid fill?
A chase is just a space created by surrounding walls - nothing is defined there that you can color. So as I said - if you want it black, you have to add it.
are you talking about the little white squares on the left and right side of your doors?
Coreed yes i am thanks
Thanks for clearing that up wwhub
Will a filled region inside the door family do what he needs?
Cavity Wall - Cavity Not Filled |
Mon, Jun 16, 2008 at 5:42:38 AM
Cavity Wall Around Bay Not Showing Correct Detail |
Sun, Jan 17, 2010 at 3:50:13 PM
Door/ Window Editing (help) |
Fri, Oct 24, 2008 at 7:28:44 AM
Joining different Cavity walls |
Mon, Jan 5, 2015 at 12:26:43 PM
Cavity wall for Revit 2008 |
Thu, May 26, 2011 at 12:06:42 PM
