Forums >> Revit Building >> Technical Support >> Rendered Tree problems in Walkthrough
Tue, Apr 13, 2010 at 10:07:14 AM | Rendered Tree problems in Walkthrough
chawley
I am rendering a walkthough and at some point the RPC plantings flip horizontally. Is there a way to control this? See the attached video clip. I am using Revit Architeture 2010.
Wed, Apr 14, 2010 at 6:48:20 AM | Rendered Tree problems in Walkthrough
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
I have seen this on bushes. Never tried trees so close. Good question. I would take them out for now and put those bushes on the ground.Edited on: Wed, Apr 14, 2010 at 7:36:23 AM
Edited on: Wed, Apr 14, 2010 at 7:36:53 AM
Thu, Apr 15, 2010 at 7:41:58 AM | Rendered Tree problems in Walkthrough
chawley
The bushes flip too. They are much more symmetrical so the movement isn’t as obvious.
Thu, Apr 15, 2010 at 9:37:20 AM | Rendered Tree problems in Walkthrough
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
WHAT IS THE TREE FAMILY CALLED?
RPC Tree - Deciduous.rfa
I DID A TEST AND THE TREE I USED DID NOT DO THAT.
Thu, Apr 15, 2010 at 9:50:09 AM | Rendered Tree problems in Walkthrough
chawley
It is RPC Tree - Deciduous.rfa. It is also flipping the RPC Shrub.rfa. I found an option in the Render Appearance Properties under the Type Properties that allows you to lock the view. I am going to try that in a walkthrough tonight.
I have rendered entire walkthrougth (40 seconds) twice and the trees and bushes horizontally flip but not always at the same spots. I don't know what is the controlling factor that is making them flip.
Rendered walkthrough is blurry
Tue, Dec 2, 2014 at 1:41:44 PM
best way to do a rendered Walkthrough video?(Student)
Mon, Sep 19, 2016 at 6:31:24 AM
Rendered Walkthrough
Thu, Jun 7, 2007 at 7:39:51 AM
Walkthrough in realistic view, not rendered
Wed, Aug 27, 2014 at 12:00:38 PM
rendered walkthrough?
Mon, Jan 2, 2012 at 1:43:19 AM
Page generation time: 3.0334
