Forums >> Revit Building >> Technical Support >> Stone Detail Component???
Mon, Apr 12, 2010 at 11:25:31 AM | Stone Detail Component???
chowlowhammond
Can anyone explain the best method for drawing stone veneer in 2D? I'm trying to draw wall sections / details... I've tried creating a detail component, but there is no way of controlling the vertical length of the veneer. Basically I would have to create a unique family for every single condition. Giant pain. Hours wasted. This should be standard stuff. See attached image. We're on Revit Architecture 2010.
Mon, Apr 12, 2010 at 11:36:40 AM | Stone Detail Component???
I don't know what you mean by controlling the length - don't you mean height?
If you have random height units then ... I guess you have to have multiple detail families....
If you have single height units, you can use them in a repeating detail.
You could mix a few random heights and use these in a repeating detail as well.
I don't know why you think this should be "standard stuff".  This isn't unit masonry.
Mon, Apr 12, 2010 at 12:32:16 PM | Stone Detail Component???
chowlowhammond
Yes, by vertical length... i meant height, ha.  And yes, the height of a stone veneer varies from section to section & especially from job to job.  I was hoping to make a standard detail component that could be used for all future jobs.  In autocad I would use x-clip to get the length I need...
By standard stuff i meant: something as common as a stone veneer in section shouldn't be so difficult.  The purpose of Revit is to speed things up, not slow things down, right?
Fri, May 31, 2013 at 3:56:19 PM | Stone Detail Component???
wcollins
If you are doing sections, then what you have is fine. Don't make a mountain out of a mole hill. If you are doing elevations, then use bit maps and use the Materials command in sttings of the manage tab and assign materials to walls as required.
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Best approach for Stone Veneer component "hatch pattern"?
Mon, Sep 29, 2025 at 7:21:02 PM
component with material and recess wall
Thu, Sep 10, 2015 at 7:22:23 AM
Stone Walls, Stone Veneer, etc
Fri, Oct 6, 2006 at 8:21:58 AM
Page generation time: 0.2802
