Forums >> Revit Building >> Technical Support >> Edit Cut Prolie Green Lines?
Sat, Apr 10, 2010 at 1:39:24 PM | Edit Cut Prolie Green Lines?
Arch145763
I was wondering if anyone knew what would cause my edit cut profile lines to turn green. I have been doing a few of them to my building section and sometimes I will edit a new profile and then all of the edits i have already done will turn green.
Sun, Apr 11, 2010 at 8:25:44 AM | Edit Cut Prolie Green Lines?
When you modify a section location ... even just a little, the edit profiles will turn green.  You will have to edit them to allow them to update.
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
green model lines
Fri, Sep 9, 2016 at 11:36:06 AM
Green object lines
Mon, Sep 12, 2016 at 9:40:03 AM
3D component strangeness, green lines and not visible in 3d
Fri, Aug 8, 2014 at 7:28:02 AM
RAC2009 - > green lines in 3d view
Thu, Aug 21, 2008 at 11:12:33 AM
Page generation time: 0.5578
