Forums >> Revit Structure >> Technical Support >> Trying to make a wall glow
Fri, Apr 9, 2010 at 10:36:17 PM | Trying to make a wall glow
RColeman
I have made a wall out of red frosted glass and was wondering if anyone knows of any ways to make it glow dimly?  I have tried playing around with where and how the lights hit it, but cannot seem to figure it out.  I also tried placing a light inside the wall, which does make it glow some, but it also make the ceiling above it too bright.  I am new to Revit and not sure if what I am trying to create is even possible.
Sat, Apr 10, 2010 at 7:17:38 AM | Trying to make a wall glow
4 Stars: 205 Votes
You can use the material to your wall, duplicate that "Glass - White High Luminance" and give another name then you must adjust the values of transparency, glossiness, Self-ilumination and color temperature to give that effect.
Play with that...
Sat, Apr 10, 2010 at 11:47:04 AM | Trying to make a wall glow
RColeman
I see that I was using the wrong glass material. I will try that and play around with the settings.
Thank you so much for setting me off onto the right path. It was driving me crazy trying to get the appearance that i wanted.
Edited on: Sat, Apr 10, 2010 at 2:48:20 PM
Sat, Apr 10, 2010 at 12:01:04 PM | Trying to make a wall glow
4 Stars: 205 Votes
You also can use the "Plastic" material like you can see in the image attached...
Sat, Apr 10, 2010 at 2:49:41 PM | Trying to make a wall glow
RColeman
Thanks, I will experiment with that material too.
Mon, Jun 30, 2014 at 2:55:20 PM | Trying to make a wall glow
davestruction
Thanks Typhoon
Render exterior view with artificial lights - how to make interior glow?
Sun, Mar 11, 2012 at 12:45:28 PM
Neon/ Glow in the Dark Signs/Lettering Anyone
Tue, Oct 28, 2008 at 8:16:26 AM
lighting fixture basic?
Tue, Feb 16, 2010 at 4:40:58 AM
2009 SHADED VIEW CAN NOT FIND "GLOW" TO MAKE CEILING LIGHTER IN COLOUR
Wed, Jan 28, 2009 at 6:04:37 PM
LED Lighting
Sun, May 27, 2012 at 4:39:10 PM
Page generation time: 4.1100
