Forums >> Revit Building >> Technical Support >> Corner Column Family Editing
Fri, Apr 9, 2010 at 12:49:44 PM | Corner Column Family Editing
dangroup
So I have taken an original column and made it a pilaster corner so it will show correctly in floor plan.  But now how do i modify the family column solids to take on materials and show the correct hatch in floor plan as well as the correct material in a render view.  Basically how do I assign materials to the solids I have added to the column family?
Sat, Apr 10, 2010 at 5:40:49 AM | Corner Column Family Editing
4 Stars: 205 Votes
In the family, pick in each component, go to the properties and you can create a parameter (that little right button) for material where you can assign the texture and the pattern (surface and cut)...
Column Family/Beam Family
Fri, Aug 27, 2010 at 1:25:52 PM
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
room bounding tolerance
Mon, Mar 8, 2010 at 2:30:54 PM
Mullions at corner of curtain walls
Thu, Jan 21, 2016 at 10:52:07 AM
Page generation time: 3.8587
