Forums >> Revit Building >> Technical Support >> Creating a Site
Fri, Apr 9, 2010 at 10:19:57 AM | Creating a Site
helminla
Cannot even start a site model. I have imported an autocad site plan and I am hoping to be able to "trace" the CAD lines in order to create my 3D site model in Revit.
Thanks.
Fri, Apr 9, 2010 at 10:22:20 AM | Creating a Site
Don't do that!  Look in your HELP : "Creating a Toposurface from Imported 3D Data"
Fri, Apr 9, 2010 at 10:24:18 AM | Creating a Site
helminla
The file I am trying to reference the site dimensions, boundaries, topograpgy, ect. from is not 3D data... I want to do this without 3D data, possible?
Fri, Apr 9, 2010 at 10:26:37 AM | Creating a Site
helminla
or, can I reference in a pdf even, something to "trace"?
Fri, Apr 9, 2010 at 10:29:05 AM | Creating a Site
4 Stars: 205 Votes
Do you have the "Z" (elevation) Labels (text) in Autocad or points with Z ???
Fri, Apr 9, 2010 at 10:30:52 AM | Creating a Site
Sure - you can just do what you were asking but there is a much easier way!
Look ... If this is a CAD file, and the topography (topo lines) are polylines, they should be set to elevations.  If not, then edit the cad file and set them.  Also make sure the topo lines are on a seperate layer from other data, then follow the HELP.
Go ahead and copy (trace) your property lines and other linework as you need it ... or just use the CAD file in appropriate views.  REVIT's topography lines don't work well so if you need a drawing with topo-lines, use the CAD.
Fri, Apr 9, 2010 at 10:40:49 AM | Creating a Site
helminla
typhoon, im not sure what you mean. help?
wwhub - err, im not certain on how to set polylines to elevations in autocad, but i'll give it a shot.
Fri, Apr 9, 2010 at 11:21:18 AM | Creating a Site
4 Stars: 205 Votes
What i'm talking about (like you can see in the image) is the LABEL of the Elevation point, it's ONLY text..... do you have that in your CAD file?
Edited on: Fri, Apr 9, 2010 at 11:22:59 AM
Fri, Apr 9, 2010 at 11:54:21 AM | Creating a Site
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I'm going to assume that your site is really not that complicated. First create the boundary using the bearings and distances table in Revit. You can do this from a paper map. Second do not try to follow contour lines Revit does not work like that. On the Site tab use the create points button and place point elevations matching the locations which you can scale on the map. Probably just a few point elevations are required. Revit will create the contours. Read your help menu about Creating toposurface. Good Luck
Fri, Apr 9, 2010 at 12:11:08 PM | Creating a Site
helminla
typhoon - yes
Fri, Apr 9, 2010 at 12:23:07 PM | Creating a Site
#11
helminla
These are the instructions from the HELP (i already have the DWG file imported):
To create a toposurface from an imported DWG file
  1. Click the Toposurface tool on the Site tab of the Design bar.
  2. On the Design bar, click Use Imported > Import Instance.
  3. Select the DWG file.
  4. Select the layers to add points from.
  5. Click OK.
  6. Click Finish Surface.
I follow, until....3. I cannot "select" the DWG file. It seems to be unresponsive.
Fri, Apr 9, 2010 at 1:16:10 PM | Creating a Site
#12
You need to import the file while you are in the topo command.
Fri, Apr 9, 2010 at 1:40:04 PM | Creating a Site
#13
4 Stars: 205 Votes
I ask you: "What i'm talking about (like you can see in the image) is the LABEL of the Elevation point, it's ONLY text..... do you have that in your CAD file?" - and you said: "typhoon - yes"
So.... watch the video: http://www.megaupload.com/?d=QK9WS65N
BUT first download and save the LISP routine into a folder...
Edited on: Wed, Apr 28, 2010 at 6:38:44 AM
Fri, Apr 9, 2010 at 3:44:49 PM | Creating a Site
#14
helminla
Thank you! this is going to be so helpful
Sat, Apr 10, 2010 at 6:19:21 PM | Creating a Site
#15
latemore
latemore Avatar
3 Stars: 2 Votes
lots of discussion here.  i'll just add a few pointers if it helps.  topos are not ideal in revit yet, but one day they'll be better.
  • if using a cad file to create a topo, make sure it is imported into the model, not just current view.  it must be a model object otherwise revit struggles to 'see' the 3d points.
  • survey data, especially contours, takes legal precedence over any contours revit can show.  so i often use the survey drawing as an underlay in site plans, and sometimes turn off the topo.
  • if the survey file has no z coordinates, it is usually not a huge ask to create the topo by putting your own points on the topo by following contours and single points.
  • selecting the layers in the cad file to create the topo is a bit hit and miss i find.  after a bit of discussion, our surveyors now have added a couple of mesh layers which work really well.  in 3d, you can see them, and it becomes easy to check what you are doing with the revit topo.  maybe ask your surveyor about this.
  • cad files will have points that are not on the ground, so it is often the case that you need to delete some.  this gets rid of those weird peaks and valleys.  our surveys give us roof and floor points when dealing with existing buildings, so watch out for that.
  • it is safer to use the select arrow over the survey boundaries for creating property lines, if you have a survey, as that is legal data.  but there is a trick.  if you change view property to true north, import the cad file (which usually has north up the page), then create the property lines, they will report their bearings as correct, if you then change the view to project north.  i now ensure i have a project with correct true north from the start, as it keeps things correct right from the start.
  • never ever use detail or model lines to emulate property lines.  well that is my take on it.  property lines have lots of uses in revit, one being able to do area assessments such as site cover.  another is perimeter.
  • when you create topos in revit it closes the outer points in a straight line.  so if you end up with a concave position of points the topo is actually incorrect, but revit knows no better.  insert points to fix this, or what we do is get the surveyor to go 1m past boundaries and we sometimes split off the 'incorrect' ones.  this is so important if you need to get accurate height lines at boundaries.
  • we obtain original natural ground meshes from our surveyor, in addition to existing ground.  so we can put 'glass' topos at the height restriction positions.  if you need to do this, try creating topos in a separate revit file, and then link it.  that way you can adjust poche in the other file, but linked files are so useful anyway.
hope some of that helps.
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:03 PM
First Time Multi-Bldg Site
Fri, Nov 30, 2012 at 7:38:45 AM
Creating CD's from a file with several linked buildings?
Mon, Sep 18, 2006 at 9:33:23 AM
creating a site the shape of a capital E
Wed, Jun 23, 2010 at 7:10:47 AM
Walls from multiple floors above showing in site plan
Wed, Oct 3, 2012 at 9:23:52 PM
Page generation time: 2.3346
