Forums >> Revit Building >> Technical Support >> Beam with arrayed holes
Fri, Apr 9, 2010 at 3:21:33 AM | Beam with arrayed holes
FrankSheiakh
I'm trying to make a beam with holes in it.
My Imagined workflow is this:
1. Make a generic family of the beam.
2. Make a generic family of the hole (Void). Load that family into a line based family and make an array.
3. Load the line based family into the beam family and link parameters to each other.
All this works fine, but I can't cut the voids from the solid geometry.
I've tried to load just a generic family vith a void and that won't cut either.
Is it so that voids cant cut if it's placed in a family and loaded into another family with solids (both Generic Models)?
Fri, Apr 9, 2010 at 5:05:40 AM | Beam with arrayed holes
Revin
It should work if you use the "cut" command (under Modify / edit geometry) to use make sure the voids cut through the beam.
Fri, Apr 9, 2010 at 6:03:09 AM | Beam with arrayed holes
FrankSheiakh
It doesn't work for me.
If I make a facebased component it works just fine.
But not if I make a Generic Model with a void in it.
I've attached a file with an example.
Fri, Apr 9, 2010 at 10:40:07 AM | Beam with arrayed holes
TomDorner
4.5 Stars: 25 Votes
If you are using Revit structure, open the cellular beam family and see how they constructed that.  If you don't have Revit Structure, download a trial version and it will install the structural families library which is handy to have even if you use Revit architecture
Tom
www.reviteer.com   http://twitter.com/Reviteer
Remove individual holes from cellular beams
Tue, Jun 17, 2008 at 1:02:33 PM
Cellular Beam (File Attached)
Tue, Feb 15, 2011 at 3:32:48 AM
Cellular Beam Families
Fri, Jan 21, 2011 at 9:27:45 AM
Fabsec Steel Beam Families
Wed, Nov 8, 2006 at 1:43:28 PM
Adaptive rectangular pattern with bubbly holes
Thu, Sep 12, 2013 at 6:31:28 AM
Page generation time: 2.0394
