Forums >> Revit Building >> Technical Support >> inport dwg with paperspace views
Thu, Apr 8, 2010 at 4:09:19 PM | inport dwg with paperspace views
SteveB
3.5 Stars: 5 Votes
revit can export a sheet with views to a paperspace autocad .dwg.   Is there a way to IMPORT a .dwg with paperspace views to create a similar sheet in revit10?
Fri, Apr 9, 2010 at 7:09:39 AM | inport dwg with paperspace views
I don't know why you even want to do this and I doubt that anyone else has tried.  Sorry.
Fri, Apr 9, 2010 at 7:11:50 AM | inport dwg with paperspace views
SteveB
3.5 Stars: 5 Votes
When consultants do drawings (in autocad), in order to print as one set, you may import their drawings.
Fri, Apr 9, 2010 at 7:52:26 AM | inport dwg with paperspace views
Ah... now I understand.  I think you will find out that that you will not want to do this.  Don't import complete CAD dwgs at all!!!   (You will soon find out why not, if you continue.) Keep your consultant's CAD files seperate and leave them in CAD.
One solution to this need is to print your files to a combined PDF and have your consultants do the same.  Then just use Adobe to combine them.
Fri, Apr 9, 2010 at 8:34:13 AM | inport dwg with paperspace views
SteveB
3.5 Stars: 5 Votes
agreed
drafting views pen weights light with linked .dwg
Fri, Nov 6, 2009 at 12:58:02 PM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
RAC 2009 export view to ACAD 2009
Tue, Dec 1, 2009 at 1:18:51 AM
importing Autocad files - modelspace & paperspace!
Tue, Jul 17, 2007 at 8:25:49 AM
Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
Thu, Nov 12, 2009 at 10:01:09 AM
Page generation time: 0.4424
