Forums >> Community >> Newbies >> Residential Wall Thickness
Thu, Apr 8, 2010 at 1:44:26 PM | Residential Wall Thickness
treeves1968
I am just curious how thick you guys that are doing residential work draw your studs? I have always drawn them 5-1/2" and 3-1/2". The problem when they are drawn that way sometimes the dimensions come out weird. Just curious how everyone does it? Any thoughts.comments would be greatly appretiated, thanks.
Thu, Apr 8, 2010 at 4:28:34 PM | Residential Wall Thickness
jarosa
jarosa Avatar
4 Stars: 5 Votes
I always use the actual dimension of the stud and my carpenters prefer it that way also. We see drawings where the walls are drawn as 5" for a 4-3/4" wall and worse yet, when they are drawn in Autocad, many times the dimension string doesn't add up. My suggestion is to model as accurately as possible. You can dimension to the center of the wall and make those dimensions as you wish.
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Revit 2013 - Window frame sweep with wall thickness
Wed, Nov 28, 2012 at 4:03:26 AM
diffrent wall thickness
Wed, Dec 6, 2006 at 3:23:00 AM
Page generation time: 0.5241
