34 Users Online (32 Members):
Forums >> Revit Structure >> Technical Support >> Cut framing with ref.plane in families?
38 Posts No Rating |
Hi, As you can cut geoemetry with a reference plane within a project I'm wondering if this can be done within a family because I cannot get it to work. What I have is a wooden beam which works fine to cut in a project, but when I load the beam into a new family it does not work to cut with a reference plane. Any ideas if this could be done? Thanks in advance, Christopher
Reference planes can't cut anything but you can limit geometry to reference planes. Download the families guide and it will show you how to do what you want. You can find this under your HELP pulldown. In that guide, pay attention to the advanced standard component families - nesting sill families into the window family. This should be a similar application to what you are doing.
Moving framing members from one Work Plane to another |
Wed, Jan 25, 2012 at 3:36:04 PM
11
What should the Revit Structure Cut Plane Depth be set to on framing sheets? |
Mon, Nov 21, 2011 at 1:44:28 PM
View range queations |
Mon, Jan 18, 2010 at 4:48:17 PM
Revit Arch 2009: Cannot align circular solid extrusion to ref plane |
Thu, Aug 25, 2011 at 3:03:35 PM
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:19:59 AM
