Forums >> Community >> Newbies >> rotating reference plan at certain time in model
Thu, Apr 8, 2010 at 1:48:55 AM | rotating reference plan at certain time in model
marklisek
Sorry ignore my other thread, i figured it out up to this point.  But one last part is to have the reference plane angle rotate at certain times in the model. This is due to the component as a solar panel, so for example: 35 degrees at 10 am 50 degrees at 1pm... etc. How do i do this?? Thank you so much!!!!
Thu, Apr 8, 2010 at 5:33:17 AM | rotating reference plan at certain time in model
4 Stars: 205 Votes
Use "Reference Lines" and create a angular dimension, then convert that dim. to a parameter.... the rest i think you already know....
Fri, Apr 9, 2010 at 12:23:16 AM | rotating reference plan at certain time in model
marklisek
how could you link the parameter to the time of day though?
thank you!
Fri, Apr 9, 2010 at 3:40:54 AM | rotating reference plan at certain time in model
4 Stars: 205 Votes
I think i'm not understanding the real question here....
Fri, Apr 9, 2010 at 7:27:11 AM | rotating reference plan at certain time in model
This can not be done automatically.  You will need to set this as a type parameter in the family that would enable you to change it globally.
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Placing 3d Model Text on a Curved Wall
Sat, Nov 21, 2009 at 5:54:42 AM
Rotating object using reference line
Wed, Sep 14, 2011 at 4:25:18 AM
Rotating Topo
Wed, Feb 3, 2010 at 6:45:53 PM
Rotating a Project
Thu, Jun 29, 2006 at 9:08:00 AM
Page generation time: 1.1143
