Forums >> Revit Building >> Technical Support >> Nesting Voids in Curtain Wall Panel
Wed, Apr 7, 2010 at 9:36:00 PM | Nesting Voids in Curtain Wall Panel
SCOTTY V
Hello All,
I am attempting to nest a void in a curtain wall panel with the intention of creating a screen.  Using voids inplace seems to slow the family down so I was hoping a could nest a void into the family.  I am using a Generic Model to make the void, and I have tried adding it to my curtain wall panel with no luck.  Is there something else I should be doing to make this work?  I've used revit for a long time now but I've never had a lot of success with making families.
 Cheers
Scott
Wed, Apr 7, 2010 at 9:41:27 PM | Nesting Voids in Curtain Wall Panel
TomDorner
4.5 Stars: 25 Votes
OK, first question, do you really need to model screens?  What kind of spacing are we talking about?  Could you accomplish the desired effect with a surface pattern and matching texture if you need to render?
If the pattern is large enough I would simply nest a new type of curtain wall into the host curtain wall and create mullions for the screen and set the panel type to empty.
If you provide a sketch or some detail maybe we can take a stab at creating a sample file.
Tom
Wed, Apr 7, 2010 at 11:16:21 PM | Nesting Voids in Curtain Wall Panel
SCOTTY V
Thanks Tom,
Yes you're right normally a pattern would suffice to show screening, however I wanted to test the effects of Perforated steel screening ( http://www.onlinemetals.com/prodimg/perforated.jpg )  I would just like to make panels that as basicly this.  It may be a really bad idea (model lag and speed) I dont know till I try.
The idea was shot down as a design option for the project I am working on about 10mins ago, but I'd still like to figure out how to do it.
Cheers
Scotty V
Thu, Apr 8, 2010 at 5:30:15 AM | Nesting Voids in Curtain Wall Panel
4 Stars: 205 Votes
Why don't you just apply that material? In Revit materials>Metal you have that kind of texture...
Just my 2 Cents....
Thu, Apr 8, 2010 at 8:15:34 PM | Nesting Voids in Curtain Wall Panel
SCOTTY V
Thanks but I'm not planning to render it.  Just want to see how it will work with animated sun studies.
Curtain Panel Family & nesting solid/voids
Mon, Mar 7, 2016 at 9:19:15 AM
Nesting curtain panel family
Mon, Mar 25, 2013 at 7:56:10 AM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall panel losses end - edge
Tue, Jul 15, 2014 at 7:04:22 PM
Nesting Families Problem
Mon, Mar 25, 2013 at 2:22:33 AM
Page generation time: 0.8054
