Forums >> Revit Building >> Technical Support >> Calculate Wall Lengths/Area
Wed, Apr 7, 2010 at 1:48:59 PM | Calculate Wall Lengths/Area
redgts93
Is there a way to add the lengths of all the walls that bound a room and add them onto a schedule? I need to calculate wall areas but the room is open on one side and a permiter takes into account all four sides, I just want the ones that have a physical wall bounding them.
 For example, the room is 10' square so it has 30' of walls (with the permiter at 40')  I want revit to calcuate the "30'" number in my example.
 Make sense?
 Thanks,
Mike
Wed, Apr 7, 2010 at 1:57:15 PM | Calculate Wall Lengths/Area
Sorry but I don't know a way to do this automatically.  Walls will not associate with a room so that is your primary problem.  Walls are usually longer than a room - they may traverse several rooms going down a corridor so that is your second problem.
Wed, Apr 7, 2010 at 2:08:20 PM | Calculate Wall Lengths/Area
redgts93
Using Area I was able to calculate sq. yards by using a calculated value in my schedule and was really hoping I could "cheat" and let Revit do the wall area for me too.  If I have to do that manually, so be it.
Wed, Apr 7, 2010 at 3:50:34 PM | Calculate Wall Lengths/Area
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this, it may help
http://revitrocks.blogspot.com/2010/03/parametric-room-size-label.html
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
How to add wall area in schedule per wall
Thu, Nov 19, 2009 at 1:10:27 PM
wall area
Thu, Jun 4, 2015 at 5:00:11 PM
12
How to quickly calculate area like in autocad?
Fri, Dec 3, 2010 at 10:50:04 AM
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
Scheduling "System" Curtain Walling Panel Parameters
Wed, Aug 27, 2014 at 9:24:13 AM
Page generation time: 0.8436
