Forums >> Revit Building >> Technical Support >> Existing doors..........................
Wed, Apr 7, 2010 at 9:52:20 AM | Existing doors..........................
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
..........is there a way to place existing doors on a plan and not have them automatically numbered?  I keep getting duplicate number warnings now that I am going through and re-numbering the new doors so they are sequential when viewed in the plan.
Wed, Apr 7, 2010 at 9:58:10 AM | Existing doors..........................
Doors are numbered from the last number used and that's up to you..... Existing doors ... Sequence them differently like E1 and the next will then be E2... When you want to go back to new doors, go back to the next number in your new sequence like if you stopped at 8, then use 9 and the next will be 10...
If you want to re-order your doors later, start with a high number like 100... Then renumber in the order you want starting with 1.
Door & Window Schedules - how to schedule existing doors and windows
Tue, Feb 3, 2009 at 11:11:39 AM
it's tagging existing doors
Mon, Apr 2, 2007 at 1:50:43 PM
Infilling element replaced by a later phase insert must be the same type as the
Wed, Jan 25, 2012 at 9:49:58 AM
Elevations in Existing Phase dont show Windows & Doors
Wed, May 6, 2009 at 4:18:46 AM
Interior Remodel
Tue, Nov 29, 2005 at 4:54:08 PM
Page generation time: 6.2606
