18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> creating pavement or lowering road- help please!
7 Posts No Rating |
hi people,
i am doing a toposurface (pretti sloped and composed).
how can I:
1) create pavements ( 20cm heigh above the topo surface level). ps: its a big urban model.
or maybe how can i lower the roads?
2)place the building exactly on their place' basing on flat dwg?
pls help
big thanks!
nik
Post edited on 2005-09-21 13:43:02
Post edited on 2005-09-21 13:43:45
Nik,
1- Use the split surface tool and draw your road with the line tool, then highlight all the point and lower/raise them the amount you need for your road off set. Do this: In Site Plan click the Split Surface tool, then click on the topo surface. Them use the Line tool and draw your roads. Click Finish Sketch, then click on the road you just created and click edit, them highlight all the elevations points and change the elevation to the number you need. Click finish surface when finished. Keep in mind that this can only be done on a level surface. If your topo is sloped you will have to change eack of your elevation point one at a time.
2-Import the flat dwaring into revit and use it as an underlay, then place your building directly in the location on the flat drawing. I do this all the time and It works very well.
Cheers, Alan
7 Posts No Rating |
thanks' that's an idea.
BUT REGARDING THE SLOPED ROADS - IS THERE ANY QUICK AND EFFECTIVE WAY TO LOWER THEM?
its very important to me, big thanks!
nik
select the road in elevation and move down... can't get much quicker than that.
1 Posts No Rating |
Hello first post here and digging up this thread after a search. I tried all the methods but the problem is there is a vertical gap between the road surface and the pavement surface. I have a 100mm high pavement so it is quite apparent there is a void there. ANy suggestions? Can we use PADs for creating sloped roads? Thanks!
Earth fill over pavement vaults |
Wed, Jun 2, 2010 at 7:33:24 AM
Road & Road Lines Error |
Mon, May 3, 2010 at 3:59:07 AM
Purple Pavement Uplighter |
Sat, Apr 8, 2006 at 4:16:08 PM
Modeling a Road in revit structure |
Thu, Jan 13, 2011 at 4:35:06 PM
Toposurface Help (Merging Surfaces) Road and Curbs |
Tue, Jul 29, 2014 at 8:10:48 AM
