Forums >> Revit Building >> Technical Support >> Curved structural members??
Tue, Apr 6, 2010 at 3:03:32 AM | Curved structural members??
dwatkins
Can anyone tell me how to create a curved bracing or column members? I am trying to design a mid level skyscraper, and the structural system is angled. I would like to make the structural system curve around the edges so that it wraps around the building, rather than being contained within a rectangular "box", is there an easy way to achieve this effect? Would I have better luck trying to create a mass that curves????
Tue, Apr 6, 2010 at 11:32:48 AM | Curved structural members??
pensing2
http://newsletters.hagerman.com/newsletters/ebul44-AEC2.htm
This is the best way of doing it.  Unfortunately, it doesn't really understand that it's a structural member, however.  You can't copy it or move it because you draw it with respect to a plane and you can't move it from this plane.  It's basically just a sweep that's shaped correctly.
Tue, Apr 6, 2010 at 11:35:56 AM | Curved structural members??
pensing2
Also, I haven't found a way yet to make it show up correctly in plan.  It will only show up in fine detail.  What I did was just draw one so that we had a place to get a section from, and then hid it in the plan and just drafted lines for the curved beams.  Not very efficient but I think it's the only way to do curved members right now.  Let me know if you find anything better!
Sloping Structural Members
Sun, Jan 9, 2005 at 5:32:40 PM
Control Default Gap between conected structural members
Mon, Jan 10, 2011 at 1:40:49 AM
Structural Members not showing up in any view- Revit Arch 2011
Thu, May 19, 2011 at 12:11:08 PM
Structural Members in Revit
Tue, Jan 20, 2009 at 6:58:51 PM
structural members along dxf lines
Mon, Oct 24, 2005 at 3:40:36 AM
Page generation time: 0.6995
