Forums >> Revit Building >> Technical Support >> Shape editing in Revit 2010
Mon, Apr 5, 2010 at 5:00:42 PM | Shape editing in Revit 2010
brlbdg
I am working on a bathroom with tile flooring that continues into the shower.  I am using the shape editing tool to create a 1/4" "threshold" to the shower and then sloping the shower area to a drain.  everything worked wonderfully except that when i added a point and lowered it for the shower drain, the surface pattern in two of the resultant planes will not align with the rest of the floor.  See the attached image.  Is there anything I can do to align the patterns on those two planes?  Thank you.
Mon, Apr 5, 2010 at 5:28:49 PM | Shape editing in Revit 2010
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I just tested this, since I wasn't 100% sure, but yes, you can use the align tool to make surface pattern lines of floor tiles, ceiling tiles, etc position rationally.
 Pick your correct tiles, then your diagonals, and they should snap into place.
Double post...?
Shape Editing Tab for "Foundation Slabs"
Thu, Jun 26, 2014 at 7:28:20 AM
difference between shape handle and editing profile?
Fri, Jun 18, 2010 at 9:00:57 AM
2010 sweep editing
Wed, Mar 24, 2010 at 4:42:34 AM
14
L shape wall without removing top and base attachments
Tue, Jun 3, 2014 at 7:33:43 AM
create-parts and multi-layered roofs with shape edits
Sun, Feb 21, 2016 at 9:27:04 AM
Page generation time: 1.4680
