Forums >> Revit Building >> Technical Support >> I can't figure out how to get the materials I want to show
Fri, Apr 2, 2010 at 1:00:03 PM | I can't figure out how to get the materials I want to show
RColeman
I started using Revit this semester and I am trying to apply materials to a booth that I have edited.  I can't seem to get the fabric that was first on the booth to go away.  I have tried to add individual material parameters between the table and the booth, but don't know what I'm doing wrong.  How can i get the materials I want to be recognized and remove the fabric?
Fri, Apr 2, 2010 at 1:13:34 PM | I can't figure out how to get the materials I want to show
Once loaded into a project, the material description is also loaded.   No matter how many times you change the familiy, if the material definition is already in the project - THE PROJECT RULES!  ... change it in the project.
Fri, Apr 2, 2010 at 2:03:52 PM | I can't figure out how to get the materials I want to show
RColeman
I don't know how to do that yet.  But thank you for getting me headed in the right direction.  I will play around some and see what i come up with.
Mon, Apr 5, 2010 at 7:23:47 AM | I can't figure out how to get the materials I want to show
Although I could give you the answer directly, that would be a disservice.  Learn to use your HELP using simple, one word searches.  In this case " materials" .... have fun.
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:07 PM
Structural beam won't show in elevation
Fri, Aug 12, 2005 at 5:22:08 PM
When editing materials through properties, only two show up??
Tue, Mar 13, 2012 at 3:38:21 PM
Adding materials into Revit's materials files
Thu, Jul 22, 2010 at 1:54:48 PM
Materials for families
Sun, Jan 21, 2007 at 8:40:59 PM
Page generation time: 4.8640
