19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Parameters in Detail Families
4 Posts No Rating |
Hello all, I'm wondering if there is a good practice for adding parameters into a detail component. Specifically, I am trying to add a length parameter that controls the depth of mullions. It's obviously easy to add a parameter to adjust the depth in the model of the mullion, but can I also make this parameter control the sketched detail lines? When I try to add the length parameter into the detail component Revit says, "That the family contains large sketches. Labeling a dimension may slow them down considerably. Continue?" thanks
We have width and depth parameters in our alum tube window details with no problems. We then have an instance parameter to control how much glass we show. You must be doing something wrong.
Linking Object in detail item to multiple parameters. |
Thu, Sep 20, 2012 at 1:05:25 PM
Scheduling Detail families |
Tue, May 8, 2012 at 6:39:15 AM
Repeating Detail in Families |
Mon, Jul 2, 2012 at 3:30:47 PM
12
Project Shared Parameters or Shared Parameters in Families |
Fri, Feb 21, 2014 at 10:22:42 AM
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
