Forums >> Revit Building >> Technical Support >> Phasing & graphic overrides
Thu, Apr 1, 2010 at 12:13:13 PM | Phasing & graphic overrides
rkbisbee
I have set my phasing so that new walls are poched dark grey.  By default, my storefront glass and mullions also poche.  Is there any way to override that?  I'd like the mullions and glass without the poche.  My intent is to poche the new WALLS only.
Wed, Apr 7, 2010 at 2:06:52 PM | Phasing & graphic overrides
Prophecy99
Prophecy99 Avatar
This all depends by the way you setup your graphic overrides.  If you filtered graphic overrides by phasing than you may have to filter the graphic overrides a step further by saying which new phase elements are overriden or not.  Try messing with Visibility Graphics - Filters.  And see if that helps you find a solution.
Edited on: Wed, Apr 7, 2010 at 2:07:55 PM
Imagination reveals truths reality obscures.
Fri, Apr 16, 2010 at 6:31:37 PM | Phasing & graphic overrides
rkbisbee
Thanks Prophecy.
 I found another work around.  I decided not to use the graphic overides in the phase filters because that overides all model elements that are assigned to the new phase.  Instead, I made a generic "new" walls and assigned them a poche in the materials setting.  That's good enough for now.
Sun, Apr 18, 2010 at 12:25:14 AM | Phasing & graphic overrides
mcantwell
mcantwell Avatar
The coarse scale fill pattern is useful in general arrangement plans
Existing walls with a coarse scale fill pattern and new walls without. Any view set to coarse differentiates new and existing
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Phase Graphic Overrides
Wed, Jul 10, 2019 at 4:01:45 PM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:55 AM
Phasing moved to Visibilty/Graphic
Wed, Nov 18, 2009 at 4:11:56 PM
conflicting graphic overrides...
Fri, Oct 12, 2012 at 10:44:04 AM
Page generation time: 0.2477
