Forums >> General Discussion >> Revit Project Management >> Small TEXT ON DRAWING TITLE WITH LINE UNDER IT, CONFUSED AND DESPERATE
Wed, Mar 31, 2010 at 9:24:13 AM | Small TEXT ON DRAWING TITLE WITH LINE UNDER IT, CONFUSED AND DESPERATE
RevitStudent123
I use Revit 09 and Structure 09. I do modeling and structure stuff in Structure. The automatic text with the line
under it on the drawings is always small. I have tried for hours playing with view properties and element properties
to change it to 1/4". I add leaders with various size text with no problem to revit generated detials.
I have read many posts and I am still lost. Thanks for anyones help.
Wed, Mar 31, 2010 at 9:38:53 AM | Small TEXT ON DRAWING TITLE WITH LINE UNDER IT, CONFUSED AND DESPERATE
Are you talking about a text note in a view, or the view title on a sheet?
Wed, Mar 31, 2010 at 3:41:25 PM | Small TEXT ON DRAWING TITLE WITH LINE UNDER IT, CONFUSED AND DESPERATE
LIZARD2806
3.5 Stars: 7 Votes
If you are talking about the drawing title on the drawing sheets, you need to update the family.  In your Project Browser, expand the Family category, then expand the Annotation Symbols category.  Right click on View Title, then click edit on the pop up menu.  You will now be editing the family in the family editor.  I recommend saving it as a different name when done.  After editing, load it back into your family.
Next, you'll have to go to a sheet view that has the view title on it. Left click on the title and then click the properties button on the options bar.  In the Element Properties dialog box, choose Edit/New.  Then under Title, choose the view title you just loaded into the drawing from the drop down list.
Let me know if that wasn;t what you were asking.
Cheers!
Edited on: Wed, Mar 31, 2010 at 3:43:17 PM
**Using Revit Architecture 2009, 2011, and 2012**
Sat, Apr 3, 2010 at 11:16:39 AM | Small TEXT ON DRAWING TITLE WITH LINE UNDER IT, CONFUSED AND DESPERATE
RevitStudent123
Thanks I will try this.
Sheet Title Text
Mon, Apr 11, 2005 at 1:39:23 PM
View Title drawing scale associated to the right and moving with the line
Wed, May 9, 2018 at 5:41:08 PM
problems with a grid line title in relation to edge of viewport
Thu, Dec 4, 2014 at 3:34:12 PM
Project title text on drawing sheets
Wed, Jun 20, 2007 at 5:26:30 PM
Stretch/move text location in Viewport Title
Wed, Sep 12, 2018 at 4:06:35 PM
Page generation time: 1.2070
