Forums >> Revit Systems >> Technical Support >> MEP plumping
Wed, Mar 31, 2010 at 2:14:40 AM | MEP plumping
Palme
Hey..
I´ve started to work with MEP2010, and I´ve haven´t worked a lot with revit before. My problem is that I kind find a fitting in plumping that goes 45 degree. The only one I´ve found here at the site dosn´t fit in my MEP....
 Please help me Smile
Fri, Apr 9, 2010 at 3:06:34 PM | MEP plumping
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
If you are talking about an elbow, the 45 or any other angle is built into the fitting. Just try drawing the piping at a 45 and it should put it in automatically. If you are looking for wyes or other bends, look in your imperial/metric library.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Can individual Objects be bound in Arch then changed in MEP
Thu, Jun 7, 2012 at 1:37:23 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Sample Mep file
Wed, Nov 10, 2010 at 12:02:37 PM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Page generation time: 1.9429
