Forums >> Revit Building >> Technical Support >> Automatic Line Weights
Tue, Mar 30, 2010 at 9:18:07 PM | Automatic Line Weights
cheryla
3 Stars: 2 Votes
Using Revit 2010
I am looking for a way to automatically show line weights per company standards. Is there a way to set up in your template to have components in a wall show up as different line weights? For example, right now when you cut a wall section only the outter layers of the wall show as bold. Is there a way to set different line weights for the different components of the wall?
Wed, Mar 31, 2010 at 6:30:48 AM | Automatic Line Weights
Read this section in your HELP>
Modifying Object Styles
All objects appeareance is set through this.
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Import & Export Line Weights - setting them
Fri, Apr 1, 2011 at 12:45:54 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:36 PM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Page generation time: 0.4521
